DPS: By default try to stay 80-85km from the enemy blob unless asked to burn away or towards enemy. Focus on killing primaries. Don't try to shoot enemy interceptors/dictors that burn for us unless told to do so or nothing else is within range. Don't cap yourself out=don't run your mwd unless you need to burn. Make sure you align where the FC tells you to align. If you don't know where to align just align somewhere away from the enemy gang so you can warp if you get primaried and logistic can't keep you up(it rarely can). When we engage large arty gangs make sure you are not aligning directly away from them, keep your transversal up so you won't get one vollied.
AntiTackle: Focus on killing everything that burns towards our gang. Usually this means killing enemy interceptors and dictors. Shoot the primary when nothing is burning for us but you need to switch target automatically(without being told to do so) if something does burn towards us.
Tackle: Lachesis has 2 LR points. Use one point for the primary and the second point to the most expensive enemy ship in your range(T3, Faction, CS). At least make sure you have 2 ships pointed at all times.
Huginn has 2 webs. Use one against primary and one against enemy tacklers that are close to our gang. If you see large(HACs and bigger) enemy ships separating from enemy gang and burning for us, don't web them until they notice they have separated and try to turn back. Let them burn for us. You need to be zoomed out and use tactical overlay to notice this.
Dictors, don't make suicide bubble runs unless asked to. Make sure you don't bubble friendly gang. If enemy blob burns towards us while we are burning away, focus on dropping a bubbles between us and the enemy gang while staying alive.
Inties, when our gang is engaged in a major fight against a blob your job is to provide warp ins for friendly gang members that have to leave the field and then warp back. You need to make sure that when friendly warps to you he doesn't get dragged in to any bubbles in the field. Usually it is enough if you burn 250km above to battlefield and stay there. X up in fleet chat when you are in position so people know who to warp to.
TO EVERYONE: Help FC to broadcast targets. When FC calls a target broadcast it if it's not broadcasted. Make sure your overview settings put the broadcasted target on top of your overview. Make sure you have at least distance, name and type set on the overview. By default sort overview out by distance.
Fits:
Oracle(T1 fit performs similar to T2 so no point wasting money on T2 guns). I changed the fit, you can still use the previous one if you have it fitted.
Spoiler:
[Oracle, More targeting range] Damage Control II Heat Sink II Heat Sink II Signal Amplifier II Tracking Enhancer II Tracking Enhancer II
Experimental 10MN MicroWarpdrive I Large Shield Extender II Adaptive Invulnerability Field II
Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L Tachyon Modulated Energy Beam I, Imperial Navy Infrared L
Medium Energy Collision Accelerator II Medium Core Defense Field Extender I Medium Core Defense Field Extender I
Also bring multi and ultraviolet
Talos(T1 fit performs similar to T2 so no point wasting money on T2 guns)
Spoiler:
[Talos, More targeting range] Magnetic Field Stabilizer II Magnetic Field Stabilizer II Magnetic Field Stabilizer II Tracking Enhancer II Tracking Enhancer II
Experimental 10MN MicroWarpdrive I Large Shield Extender II Large Azeotropic Ward Salubrity I Large F-S9 Regolith Shield Induction
425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L 425mm Prototype Gauss Gun, Caldari Navy Lead Charge L
Medium Ionic Field Projector I Medium Core Defense Field Extender I Medium Hybrid Locus Coordinator I
Warrior II x5
also bring antimatter and uranium
Naga (only bring this if you can't bring Oracle or Talos)
Spoiler:
[Naga, more range] Magnetic Field Stabilizer II Magnetic Field Stabilizer II Magnetic Field Stabilizer II
Experimental 10MN MicroWarpdrive I Tracking Computer II, Optimal Range Script Tracking Computer II, Tracking Speed Script Adaptive Invulnerability Field II Large Shield Extender II Large Shield Extender II
425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L 425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L
Medium Ancillary Current Router I Medium Core Defense Field Extender I Medium Ionic Field Projector I
Drake (changed fit back to the original)
Spoiler:
[Drake, Dual web] Ballistic Control System II Ballistic Control System II Nanofiber Internal Structure II Nanofiber Internal Structure II
Experimental 10MN MicroWarpdrive I Large Shield Extender II Large F-S9 Regolith Shield Induction Warp Disruptor II Stasis Webifier II Stasis Webifier II
Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile 5W Infectious Power System Malfunction
Medium Core Defense Field Extender I Medium Core Defense Field Extender I Medium Core Defense Field Extender I
Warrior II x5
Zealot:
Spoiler:
[Zealot, Fleet] Overdrive Injector System II Heat Sink II Heat Sink II Heat Sink II Damage Control II Tracking Enhancer II Tracking Enhancer II
Experimental 10MN MicroWarpdrive I Large F-S9 Regolith Shield Induction Large F-S9 Regolith Shield Induction
Heavy Pulse Laser II, Scorch M Heavy Pulse Laser II, Scorch M Heavy Pulse Laser II, Scorch M Heavy Pulse Laser II, Scorch M Heavy Pulse Laser II, Scorch M
Medium Core Defense Field Extender I Medium Energy Locus Coordinator II
I don't recommend brining zealot if you don't have HAC5 and T2 rig fitted.
Lachesis(looks retarded but I don't trust your cap management with standard invu+cap booster fit, you can replace 1xLSE with Invu if you know how to manage cap, only use smartbombs if you are surrounded by ecm drones)
Spoiler:
[Lachesis, Dual LR point buffer] Damage Control II Capacitor Power Relay II Capacitor Power Relay II
Experimental 10MN MicroWarpdrive I Warp Disruptor II Warp Disruptor II Large Shield Extender II Large Shield Extender II Large Shield Extender II Large Shield Extender II
Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile Small 'Vehemence' Shockwave Charge Small 'Vehemence' Shockwave Charge
Warrior II x5 Warrior II x3
Feel free to fit faction points if you are confident
Huginn
Spoiler:
[Huginn, Fleet] Damage Control II Nanofiber Internal Structure II Nanofiber Internal Structure II
Experimental 10MN MicroWarpdrive I Fleeting Propulsion Inhibitor I Fleeting Propulsion Inhibitor I Large Shield Extender II Large Shield Extender II Large Shield Extender II
Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile 200mm AutoCannon II, Republic Fleet EMP S 200mm AutoCannon II, Republic Fleet EMP S 200mm AutoCannon II, Republic Fleet EMP S
Feel free to fit faction webs. Also like with Lach, I don't really care what you fit on your high slots
Dictors (I have never flown a dictor and made these fit on the fly, if you have better ones bring them instead)
Spoiler:
[Sabre, Fleet dual bubble] Co-Processor II Co-Processor II
Limited 1MN MicroWarpdrive I Medium Shield Extender II Medium Shield Extender II Warp Scrambler II
Interdiction Sphere Launcher I, Warp Disrupt Probe Interdiction Sphere Launcher I, Warp Disrupt Probe 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S
Small Core Defense Field Extender I Small Core Defense Field Extender I
Spoiler:
[Flycatcher, Fleet dual bubble] Co-Processor II
Limited 1MN MicroWarpdrive I Medium Shield Extender II Medium Shield Extender II Adaptive Invulnerability Field II J5b Phased Prototype Warp Scrambler I
Interdiction Sphere Launcher I, Warp Disrupt Probe Interdiction Sphere Launcher I, Warp Disrupt Probe 125mm Gatling AutoCannon II, Republic Fleet EMP S [empty high slot] [empty high slot] [empty high slot] [empty high slot] [empty high slot]
Spoiler:
[Heretic, New Setup 1] Damage Control II Co-Processor II Co-Processor II
Limited 1MN MicroWarpdrive I Medium Shield Extender II J5b Phased Prototype Warp Scrambler I
Interdiction Sphere Launcher I, Warp Disrupt Probe Interdiction Sphere Launcher I, Warp Disrupt Probe 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S OE-5200 Rocket Launcher, Caldari Navy Mjolnir Rocket OE-5200 Rocket Launcher, Caldari Navy Mjolnir Rocket
Spoiler:
[Eris, New Setup 1] Damage Control II Co-Processor II Co-Processor II Nanofiber Internal Structure II
Interdiction Sphere Launcher I, Warp Disrupt Probe Interdiction Sphere Launcher I, Warp Disrupt Probe 125mm Light 'Scout' Autocannon I, EMP S [empty high slot] [empty high slot] [empty high slot] [empty high slot] [empty high slot]
Interceptors(only these ceptors are allowed, you can modify fits if you know what you are doing):
Spoiler:
[Malediction, Fleet] Damage Control II Nanofiber Internal Structure II Signal Amplifier II
Limited 1MN MicroWarpdrive I Medium F-S9 Regolith Shield Induction Warp Disruptor II
125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S 125mm Gatling AutoCannon II, Republic Fleet EMP S [empty high slot]
Small Ionic Field Projector I Small Ionic Field Projector I
Spoiler:
[Stiletto, Fleet] Damage Control II Type-D Attenuation Signal Augmentation Micro Auxiliary Power Core I
Limited 1MN MicroWarpdrive I Medium Shield Extender II Warp Disruptor II J5b Phased Prototype Warp Scrambler I
Spoiler:
[Ares, Fleet] Damage Control II Signal Amplifier II Signal Amplifier II Micro Auxiliary Power Core I
Small Ionic Field Projector I Small Core Defense Field Extender I
Spoiler:
[Raptor, Fleet] Damage Control II Signal Amplifier II Micro Auxiliary Power Core II
150mm Light AutoCannon II, Republic Fleet EMP S 150mm Light AutoCannon II, Republic Fleet EMP S 150mm Light AutoCannon II, Republic Fleet EMP S [empty high slot]
Logistic
Spoiler:
[Scimitar, Standard] Damage Control II Capacitor Power Relay II Capacitor Power Relay II Capacitor Power Relay II
Experimental 10MN MicroWarpdrive I Large F-S9 Regolith Shield Induction Conjunctive Ladar ECCM Scanning Array I Invulnerability Field II Invulnerability Field II
Large S95a Partial Shield Transporter Large S95a Partial Shield Transporter Large S95a Partial Shield Transporter 125mm Gatling AutoCannon II, EMP S
Medium Ancillary Current Router I Medium Capacitor Control Circuit I
Joined: Sat Sep 11, 2010 8:38 am Posts: 658 Location: British Columbia, Canada
Rep: 74
this is one here is the latest podla drake. same speed, same dmg, +50% ehp
Spoiler:
[Drake, podla] Damage Control II Nanofiber Internal Structure II Ballistic Control System II Ballistic Control System II
Experimental 10MN MicroWarpdrive I Large Shield Extender II Invulnerability Field II X5 Prototype Engine Enervator Stasis Webifier II Warp Disruptor II
Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Heavy Missile Launcher II, Trauma Fury Heavy Missile Salvager I
Medium Polycarbon Engine Housing I Medium Core Defence Field Extender I Medium Core Defence Field Extender I
Warrior II x5
_________________ "Ignore the ramblings of the ignorant, and step on or over their crumpled bodies as you make your way to the top of the mountain. Eat upon their flesh for fuel, and, through your determination and will, banish them to obscurity and a life of complacency and self righteousness that is the hell in which they live" - Richard Safreed
Good luck with your new project. Its a great idea. Think your first roam might be a bit chaotic but should be fun all the same.
now, I was looking over the oracle fit. I'm not so sure you are right with your statement "Oracle(yes, T1 fit does more dps than T2 unless you have spec 5)" i got spec 4 and from what i can make out, the T2 guns do about 8% more damage than the t1 best named, 6% with spec 3. someone check this?
If you fit T2 guns you need to use fitting modules, with T1 guns you don't have to. This brings the dps to same level.
you are right about the fitting. I have the Genolution implant set plugged in and forget at times. Makes things much easier to fit
Users browsing this forum: Google [Bot] and 13 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
