It is currently Sat Jun 21, 2025 2:40 am
Post a new topicPost a reply Page 1 of 5   [ 50 posts ]
Go to page 1, 2, 3, 4, 5  Next
 Post subject: Daily Roams
PostPosted: Thu Apr 05, 2012 1:47 pm
Rep: 68
Check out: https://forums.eveonline.com/default.aspx?g=posts&t=91959&find=unread
LR Tier3 BC Roam
When: Wednesday 25th 18:00
Where: Autaris/Jan (going to North)
FC: Leeloo Malaquin
DPS: Tachyon Oracles, Rail Talos, Rail Naga
AntiTackle: DualWeb Drakes, Pulse Zealots
Tackle: Lachesis, Huginn, Dictors and Inties.
Reserved spots:
Scimitar 1:
Scimitar 2:
Lachesis 1:
Lachesis 2:
Huginn 1:
Huginn 2:
Dictor 1:
Tengu links:
Loki links:
Tips:
DPS:
By default try to stay 80-85km from the enemy blob unless asked to burn away or towards enemy. Focus on killing primaries. Don't try to shoot enemy interceptors/dictors that burn for us unless told to do so or nothing else is within range. Don't cap yourself out=don't run your mwd unless you need to burn. Make sure you align where the FC tells you to align. If you don't know where to align just align somewhere away from the enemy gang so you can warp if you get primaried and logistic can't keep you up(it rarely can). When we engage large arty gangs make sure you are not aligning directly away from them, keep your transversal up so you won't get one vollied.
AntiTackle:
Focus on killing everything that burns towards our gang. Usually this means killing enemy interceptors and dictors. Shoot the primary when nothing is burning for us but you need to switch target automatically(without being told to do so) if something does burn towards us.
Tackle:
Lachesis has 2 LR points. Use one point for the primary and the second point to the most expensive enemy ship in your range(T3, Faction, CS). At least make sure you have 2 ships pointed at all times.
Huginn has 2 webs. Use one against primary and one against enemy tacklers that are close to our gang. If you see large(HACs and bigger) enemy ships separating from enemy gang and burning for us, don't web them until they notice they have separated and try to turn back. Let them burn for us. You need to be zoomed out and use tactical overlay to notice this.
Dictors, don't make suicide bubble runs unless asked to. Make sure you don't bubble friendly gang. If enemy blob burns towards us while we are burning away, focus on dropping a bubbles between us and the enemy gang while staying alive.
Inties, when our gang is engaged in a major fight against a blob your job is to provide warp ins for friendly gang members that have to leave the field and then warp back. You need to make sure that when friendly warps to you he doesn't get dragged in to any bubbles in the field. Usually it is enough if you burn 250km above to battlefield and stay there. X up in fleet chat when you are in position so people know who to warp to.
TO EVERYONE:
Help FC to broadcast targets. When FC calls a target broadcast it if it's not broadcasted. Make sure your overview settings put the broadcasted target on top of your overview. Make sure you have at least distance, name and type set on the overview. By default sort overview out by distance.
Fits:
Oracle(T1 fit performs similar to T2 so no point wasting money on T2 guns). I changed the fit, you can still use the previous one if you have it fitted.
[Oracle, More targeting range]
Damage Control II
Heat Sink II
Heat Sink II
Signal Amplifier II
Tracking Enhancer II
Experimental 10MN MicroWarpdrive I
Large Shield Extender II
Adaptive Invulnerability Field II
Tachyon Modulated Energy Beam I, Imperial Navy Infrared L
Medium Energy Collision Accelerator II
Medium Core Defense Field Extender I
Also bring multi and ultraviolet
Talos(T1 fit performs similar to T2 so no point wasting money on T2 guns)
[Talos, More targeting range]
Magnetic Field Stabilizer II
Large Azeotropic Ward Salubrity I
Large F-S9 Regolith Shield Induction
425mm Prototype Gauss Gun, Caldari Navy Lead Charge L
Medium Ionic Field Projector I
Medium Hybrid Locus Coordinator I
Warrior II x5
also bring antimatter and uranium
Naga (only bring this if you can't bring Oracle or Talos)
[Naga, more range]
Tracking Computer II, Optimal Range Script
Tracking Computer II, Tracking Speed Script
425mm Prototype Gauss Gun, Caldari Navy Thorium Charge L
Medium Ancillary Current Router I
Drake (changed fit back to the original)
[Drake, Dual web]
Ballistic Control System II
Nanofiber Internal Structure II
Warp Disruptor II
Stasis Webifier II
Stasis Webifier II
Heavy Missile Launcher II, Caldari Navy Scourge Heavy Missile
5W Infectious Power System Malfunction
Warrior II x5
Zealot:
[Zealot, Fleet]
Overdrive Injector System II
Heat Sink II
Heat Sink II
Heat Sink II
Damage Control II
Heavy Pulse Laser II, Scorch M
Medium Energy Locus Coordinator II
I don't recommend brining zealot if you don't have HAC5 and T2 rig fitted.
Lachesis(looks retarded but I don't trust your cap management with standard invu+cap booster fit, you can replace 1xLSE with Invu if you know how to manage cap, only use smartbombs if you are surrounded by ecm drones)
[Lachesis, Dual LR point buffer]
Damage Control II
Capacitor Power Relay II
Warp Disruptor II
Warp Disruptor II
Heavy Missile Launcher II, Caldari Navy Mjolnir Heavy Missile
Small 'Vehemence' Shockwave Charge
Warrior II x5
Warrior II x3
Feel free to fit faction points if you are confident
Huginn
[Huginn, Fleet]
Damage Control II
Fleeting Propulsion Inhibitor I
200mm AutoCannon II, Republic Fleet EMP S
Warrior II x5
Warrior II x3
Feel free to fit faction webs. Also like with Lach, I don't really care what you fit on your high slots
Dictors (I have never flown a dictor and made these fit on the fly, if you have better ones bring them instead)
[Sabre, Fleet dual bubble]
Co-Processor II
Co-Processor II
Limited 1MN MicroWarpdrive I
Medium Shield Extender II
Warp Scrambler II
Interdiction Sphere Launcher I, Warp Disrupt Probe
125mm Gatling AutoCannon II, Republic Fleet EMP S
Small Core Defense Field Extender I
[Flycatcher, Fleet dual bubble]
Co-Processor II
J5b Phased Prototype Warp Scrambler I
[empty high slot]
[empty high slot]
[empty high slot]
[empty high slot]
[empty high slot]
[Heretic, New Setup 1]
Damage Control II
Co-Processor II
Co-Processor II
OE-5200 Rocket Launcher, Caldari Navy Mjolnir Rocket
[Eris, New Setup 1]
Damage Control II
Co-Processor II
Co-Processor II
125mm Light 'Scout' Autocannon I, EMP S
[empty high slot]
[empty high slot]
[empty high slot]
[empty high slot]
[empty high slot]
Interceptors(only these ceptors are allowed, you can modify fits if you know what you are doing):
[Malediction, Fleet]
Damage Control II
Signal Amplifier II
Medium F-S9 Regolith Shield Induction
Warp Disruptor II
[empty high slot]
Small Ionic Field Projector I
[Stiletto, Fleet]
Damage Control II
Type-D Attenuation Signal Augmentation
Micro Auxiliary Power Core I
Warp Disruptor II
[empty high slot]
[empty high slot]
[empty high slot]
[Ares, Fleet]
Damage Control II
Signal Amplifier II
Signal Amplifier II
Warp Disruptor II
[empty high slot]
[empty high slot]
[Raptor, Fleet]
Damage Control II
Signal Amplifier II
Micro Auxiliary Power Core II
Warp Disruptor II
150mm Light AutoCannon II, Republic Fleet EMP S
[empty high slot]
Logistic
[Scimitar, Standard]
Damage Control II
Conjunctive Ladar ECCM Scanning Array I
Large S95a Partial Shield Transporter
125mm Gatling AutoCannon II, EMP S
Medium Capacitor Control Circuit I
Warrior II x5
Warrior II x4
 Post subject: Re: Daily Roams
PostPosted: Thu Apr 05, 2012 2:14 pm
Rep: 89
first i thought that i might come in XO#E SABRE
but then i realised that i dont have probe launching skills and never flied a dictor :intigo:
PostPosted: Thu Apr 05, 2012 2:23 pm
Rep: -2
I'll be there :ironicat:
PostPosted: Thu Apr 05, 2012 4:14 pm
Rep: 190
That's really cool Leelo, saturday isn't very good for me but I'll try to attend on sundays/during the week
PostPosted: Fri Apr 06, 2012 2:15 am
Rep: 74
this is one here is the latest podla drake. same speed, same dmg, +50% ehp
[Drake, podla]
Damage Control II
X5 Prototype Engine Enervator
Stasis Webifier II
Warp Disruptor II
Heavy Missile Launcher II, Trauma Fury Heavy Missile
Salvager I
Medium Polycarbon Engine Housing I
Medium Core Defence Field Extender I
Warrior II x5
"Ignore the ramblings of the ignorant, and step on or over their crumpled bodies as you make your way to the top of the mountain. Eat upon their flesh for fuel, and, through your determination and will, banish them to obscurity and a life of complacency and self righteousness that is the hell in which they live" - Richard Safreed
PostPosted: Fri Apr 06, 2012 2:25 am
Rep: 68
Ok, I replace the drake fit with the new one. Thanks
PostPosted: Fri Apr 06, 2012 9:19 pm
Good luck with your new project. Its a great idea. Think your first roam might be a bit chaotic but should be fun all the same.
now, I was looking over the oracle fit. I'm not so sure you are right with your statement "Oracle(yes, T1 fit does more dps than T2 unless you have spec 5)" i got spec 4 and from what i can make out, the T2 guns do about 8% more damage than the t1 best named, 6% with spec 3. someone check this?
PostPosted: Fri Apr 06, 2012 10:03 pm
Rep: 68
If you fit T2 guns you need to use fitting modules, with T1 guns you don't have to. This brings the dps to same level.
PostPosted: Fri Apr 06, 2012 10:31 pm
Rep: 50
not to mention meta tachs are cheaper
PostPosted: Sat Apr 07, 2012 12:32 am
you are right about the fitting. I have the Genolution implant set plugged in and forget at times. Makes things much easier to fit :)
Users browsing this forum: No registered users and 21 guests
